turin said:
What do you mean, "solve". In what sense is the plane wave state unsolved?
Oh sorry, the question asks me to show that \psi(x) = exp(ikx) is a solution of the time-independent schrodinger equation.
turin said:
I presume that the potential term in your SE is constant?
The potential is zero, yes. So I get the equation for Psi as:
\Psi(x,t) = \exp(ikx).exp(-iEt/\hbar)
From the separation of variables stuff.
turin said:
Please explain why that is obvious. That is nothing more than an interpretation of nonrelativistic QM, and it follows from nothing. There are in fact QM interpretations in which this is not true.
Well yeah ok, its not obvious on that sort of scope, I am just doing an exam paper here.
The question asks me to work out the energy in terms of k, having shown that \psi(x) = exp(ikx) is a solution to the TISE.
By mistake I've assumed this energy, which is constant, was the same value as \psi(x). This is obviously wrong which I've realized.
The energy I worked out was
E = \frac{\hbar^{2}k^{2}}{2m}
I shouldn't have said "obvious", but the probability per unit length is |\Psi(x,t)|^{2}, is it not?
turin said:
This is a rather round about way of saying ... something ... but I did not quite follow. I think what you are trying to say is that the modulus of a complex number is independent of its phase.
Well I don't know, i'll show you exactly what I am talking about:
|\Psi(x,t)|^{2} = |exp(-iEt/\hbar)|^{2}.|\psi(x)|^{2}<br />
= |\psi(x)|^{2}
I didnt understand why this was so.
turin said:
No, it's not! What are you talking about?
Yeah this follows on from my previous mistake, assuming that smal phi was the energy constant above.
The question says:
"What is the corresponding time-dependent solution,
\Psi(x,t)?
Show that the probability per unit length of finding a particle is constant (independent of both space and time)."
This, I assume is where the above workings come into place, basically showing that
|\Psi(x,t)|^{2} is constant. Is this right?
turin said:
Indeed: complex analysis. Do you know what a complex number is?
Yes of course, but I am unfamiliar with what's going on with this modulus business.
Where I am confused now is that how can the probability per unit length be constant if these complex terms are dissapearing? Wouldnt |\psi(x)|^{2} disappear also? And even if it didnt how can it be independent of space?
Can you explain to me or link me to somewhere which explains this:
= |\psi(x)|^{2}
