Calculating Kinetic Energy Change on a Ramp: KE and Friction Homework Solution"
  • Thread starter gansta344u
  • Tags
    Friction
In summary, the box of clothes was pulled up a 39.5◦ ramp by a force of 119 N. The acceleration of gravity was 9.81 m/s2, and if the coefficient of kinetic friction between the box and ramp is 0.23, calculate the change in the box’s kinetic energy.
gansta344u
25
An 83.6 N box of clothes is pulled 20.1 m up
a 39.5◦ ramp by a force of 119 N that points
along the ramp.
The acceleration of gravity is 9.81 m/s2 .
If the coefficient of kinetic friction between
in the box’s kinetic energy. Answer in units J
Ff=u(k)Fn
KE=1/2mv^2
I am a little bit confused on this problem. I think i have to add up all the forces by multiplying the normal force and uk. Also then i think we have to find the x-value of the force acting on the angle but i can't seem to put it all together or find a formula which helps me put everything together . Please if possible i kinda need help in both the concept and the formula
Draw the weight vector straight down from the box.
Resolve that into a vector along the ramp plus another one straight into the ramp.
Use trigonometry to find these parallel and normal vectors.
Then you can find the force of friction.
You could then continue analyzing the forces, find the acceleration and then the final velocity.
Or you could work with energy formulas to find the KE.
`i don't think i quite understand the method of drawing so can u please try to explain it more if possible because i don't understand what to do. If possible can you show me a algebraic method
You must draw the diagram before you can do the algebra!
It works a little nicer if you put the box right at the top of the ramp.
Draw the weight vector as an arrow that begins on the box and goes straight down.
Starting at the same place on the box, draw an arrow that goes along the ramp. Then another arrow that begins at the end of that one and goes to the end of the weight vector. You have shown the weight vector as the sum of a force along the ramp and a force into the ramp.
Something like this:
Mark your angle on the ramp and also in the triangle of the forces.
Use trigonometry to find the normal and parallel forces.
Then you can calculate the force of friction with your formula.
i think u misinterpreted the question , It says pulled up so i think the box should be at the bottom and the weight cannot be the sum of the other forces b/c the weight is the hypotenuse but the force is greater then it which cannot be possible since the hypotnuse is the longest side
Nevertheless, you need to find those parallel and normal components of the weight before you can find the force of friction. I didn't say the box was at the top, just that drawing it at the top seems to make it easier to draw the two blue vectors.
i really still don't get this . First of all the weight cannot be the hypotenuse because it is weaker in value then the force applied which is 119N compared to the 83.6N weight so to me it seems impossible can u please try to explain a little bit more clearly on what I am supposed to do because i don't get the whole point of the diagram and what we are supposed to solve b/c it seems to me this is only have of it and if u can just let me know what angle or what line we are supposed to find. TO find a line or angle u do use arithmetic so if u can just let me knw what line or angle i have to find and i can do that. that is simple but right know all I am doing is guessing on how to slve i don't understand it so if u can again please explain anyone please explain!> i really don't get by what u are trying to say by parallel forces
1. What is kinetic energy?
Kinetic energy (KE) is the energy an object possesses due to its motion. It is defined as one-half of the mass of an object multiplied by the square of its velocity.
2. How is kinetic energy calculated?
The equation for kinetic energy is KE = 1/2 * mv2, where m is the mass of the object and v is the velocity. It is important to note that KE is directly proportional to both mass and velocity, meaning an increase in either will result in an increase in KE.
3. What is the relationship between KE and friction?
Friction is a force that opposes motion, and as such, it acts to decrease the kinetic energy of an object. This is because friction converts some of the object's kinetic energy into heat energy.
4. How does friction affect the speed of an object?
Friction causes a decrease in the speed of an object over time. This is due to the fact that as friction converts kinetic energy into heat energy, there is less energy available to maintain the object's speed.
5. Can friction ever increase the kinetic energy of an object?
No, friction can never increase the kinetic energy of an object. As stated previously, friction converts kinetic energy into heat energy, resulting in a decrease in the object's kinetic energy.
