Kepler's Third Law: Proportional Orbit Period to Distance^1.5
Kepler's Third Law states that the square of the orbital period of a planet is directly proportional to the cube of the semi-major axis of its orbit. In the case of two gravitationally bound stars of equal mass, their orbital period (tau) can be shown to be proportional to the distance (d) raised to the power of 1.5, or d^(3/2). The radius of each star's orbit is directly related to the distance between them, which is crucial for deriving the relationship. Understanding these principles allows for the calculation of orbital periods based on their separation. This discussion emphasizes the mathematical relationship between orbital period and distance in a binary star system.
eku_girl83
Two gravitionally bound stars with equal masses m, separated by a distance d, revolve about their center of mass in circular orbits. Show that the period tau is proportional to d^1.5
Could someone get me started on this? I have no idea where to begin!
Thanks!
First of all, state Keppler's Third Law.
Also, realize that d^1.5 is the same as d^(3/2)
And then notice how the radius of the orbits is directly proportional to the distance between them.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
