Meeting Time and Distance between Two Towns
The discussion centers on a physics exam question involving two individuals, Kevin and Peter, traveling towards each other from Town A and Town B, respectively. Kevin moves at a constant speed of 30 m/s, while Peter accelerates from rest at 1.5 m/s². The main challenge is to determine the distance from Town A where they will meet and the time it takes for this to occur. Participants suggest connecting the equations for both individuals using their displacements and time, with one noting that a quadratic equation arises in the process. The conversation emphasizes the importance of correctly defining variables and understanding the relationship between their distances.
physnotmything
Hi everyone, i have a exam coming up for Physics and this question from the kinematic unit is really bothering me. I've tried many times but i have no idea how to solve it. Some help would be greatly appreciated, thanks. :smile:
Question: Town A and Town B are 6.0 x 10^2 (600) meters apart. Kevin leaves Town A and heads for Town B at a constant speed 30m/s. Peter leaves Town B at the same time and heads for Town A at an acceleration 1.5 m/s^2 from rest.
a) at what distance from Town A will they meet each other?
b) How much time passes before they meet?
I used only this equation so far
Delta d = (Velocity 1)( delta time) + 1/2 (acceleration) (delta time)^2
I've stated some of the unknowns from Kevin and Peter, and found only the following.
Kevin-
Velocity 1 = 30 m/s
displacement Kevin = Displacement Peter
Peter-
acceleration = -1.5
velocity 1 = 0
displacement Peter = Displacement Kevin
Using those information i tried connecting the two equations with the same unknown variable. But I only got one equation, and it was for Peter.
delta D = v1(t) + 1/2 (a)(t)^2
= 0(t) + 1/2(-1.5)(t)^2
= -0.75(t)^2
I don't get why your acceleration for Peter is negative, if he is accelerating towards Town A. Also, I am confused by your displacement Kevin = displacement Peter. You can put the distance Peter travels in terms of the distance Kevin travels, since you know the separation between A and B. I'm not sure which unknown you were trying to connect them with, but find an expression for the distance each person travels, and look at what variable would be the common one. Base your substitution on that, and solve the resulting equation. (I got a quadratic :eek: )
Hope that helps.
The quadratic seems to be unavoidable.
IT makes sense to me to solve for t first.
