Kinematics of pantograph device
The discussion focuses on obtaining the forward and inverse kinematics of a pantograph device, which is characterized as a 2DOF planar elbow mechanism. The challenge arises from the need to combine two symmetrical planar elbow mechanisms due to the closed-loop nature of the pantograph. The key to solving this problem lies in understanding that each cell of the pantograph forms a rhombus, with perpendicular diagonals that create right triangles. The motors control joints Q1 and Q3, while Q2 and Q4 adjust accordingly. A clear approach to the kinematics involves leveraging the geometric properties of the rhombus and the relationships between the joints.
zoom1
I need to obtain the forward and inverse kinematics of a pantograph device. It is easy when only the one side of the pantograph is considered; So, it becomes a 2DOF planar elbow mechanism, which is easy to solve. However, there is symmetry on pantograph, so I kinda need to combine two planar elbow mechanism, but it confuses me since it's a closed loop mechanism.
This is the depiction of the mechanism;
http://i.imgur.com/M3ANKre.png
Q1 and Q3 are controlled with the motors and Q2 and Q4 rotates accordingly.
How am I supposed to approach this mechanism ?
The key to a pantograph is that each cell forms a rhombus, and the diagonals of a rhombus are always perpendicular. So you are dealing with right triangles.
Chet
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
