When and where will two bikers meet?
Two bikers are traveling towards each other from towns 20km apart, with speeds of 20km/h and 15km/h. To determine when and where they will meet, set up equations for the distance each biker travels over time. The time will be the same for both bikers at the point of meeting, and their combined distances should equal 20km. Using the equation d = d0 + v0t, establish the initial positions and speeds for both bikers. The goal is to find the time when the distance between them becomes zero, which will also indicate their meeting point.
seanspan
There are two towns that are 20km apart. A biker leaves town#1 traveling at 20km/h and at the same time another biker leaves town#2 traveling at 15km/h. Where and when will they meet?
Given
d=20km between 2 towns
V biker 1=20km/h
V biker 2=15km/h
d=v1t+1/2at^
I know that you have to somehow make two equations and make them equal to each other and then solve for d and sub it into one of the equations to solve for t but I am having trouble starting please help
Think of what will be equal for both bikers when they meet. Is the distance they've traveled the same? The time perhaps?
well the time will be equal i know that I am just having trouble with how to set it up. I assume you have to make 2 equations and then make them equal to each other I am just not sure what the equations should be.
Correct, you'll have two equations that you'll need to equate. But, the applicable equation really should be the general form d = d0 + v0t + 1/2at2 where d0 represents the initial distance (i.e. postion) at t=0 with respect to a chosen coordinate system/origin. For example, if you choose the origin to be the initial starting point of the 1st biker, then d0 = 0 for the 1st biker. Using the same origin, think about what d0 would be for the 2nd biker and what happens over time. In the end, you want to find the time at which both bikers are in the same position (with respect to the same orgin), and from that you can find the location. When you write the equations, be careful to use the correct sign for each term based on the origin and direction of postive distance that you choose.
A different (and perhaps easier) approach would be to write a single equation that represents the distance between the two bikers. The time you are looking for is the time at which the distance between them is zero.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
