Solve Kinematics Problem: 3x Max Height, Find Angle
To determine the angle when the reach is three times the maximum height, the formulas for reach and maximum height were combined, resulting in the equation 3sin(θ)/2 = 2cos(θ). The discussion confirms that the approach to isolate θ was correct. The final step involves using a calculator to find arctan(4/3) to solve for the angle. This method effectively addresses the kinematics problem posed. The solution is confirmed as accurate and straightforward.
Johnny Blade
What is the angle if the reach is three (3) times the maximum height.
I put both of the reach and max height formula together to isolate theta
p=\frac{V_{0}^{2}sin(2\theta)}{-g} and h_{max}=\frac{V_{0}^{2}sin^{2}\theta}{-2g}
At the end it gave me this:
\frac{3sin\theta}{2}=2cos\theta
Am I getting rusty on my trigonometry? How would you solve this?
your solution was right, all u have to do then is to plug it into your calculator and calculate arctan4/3
I see it. Thank you very much.
