Kinetic and Potential Energy calculation
The discussion focuses on calculating gravitational potential energy and kinetic energy for a particle in a hemispherical bowl. The particle's potential energy at point A is calculated as 0.633 J, and its kinetic energy at point B is found to be 0.62 J with a speed of 2.4 m/s. The potential energy at point C is determined to be 0.422 J. A participant seeks assistance in calculating the kinetic energy at point C, which is stated to be 0.211 J in the book, while their calculation yielded 0.43 J. The correct approach involves applying the conservation of energy principle between points B and C.
Blubla
A 215 g particle is released from rest at point A inside a smooth hemispherical bowl of radius 30.0 cm. Point B to C have Height= 2/3(R)
Calculate the following: A. The gravitational potential energy at A relative to B
B. The particle's kinetic energy at B
c. Th particle's speed at B
D. The potential energy and kinetic energy at C
I solved A,B,C and D(The potential Energy but not the kinetic energy)
Here is my work:
A. Changed 215 g into Kg so it will be 0.215 kg
30.0 cm into m so it will be 0.30m
PE=mgh
PE=0.215*9.81*0.30
PE=0.633J
B. KE= 1/2mv^2
KE=1/2*0.215*2.4^2
KE=0.62JC. V^2f=2gh
V^2f=2*9.81*030
V^2f=5.9 Apply square root
Vf= 2.4m/s
D. PE=mgh
PE=0.30*9.8(2/3*0.30)
PE=0.422
Can someone please help me find the KE at C, the answer is 0.211J according to the book. Well, what I got is 0.43J..
Thanks in advance.
You missed the point of the problem. Use conservation of energy.
That is true, you need to use the conservation of energy between C and B.
mgR= KEc + mg(2/3)R
KEc=1/3mgR=0.211J
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
