What is the Change in Kinetic Energy of a Box Pulled Up a Ramp with Friction?
In summary, an 85.8 N box of clothes is pulled 24.5 m up a 21.1◦ ramp by a force of 118 N that points along the ramp. The acceleration of gravity is 9.81 m/s2 . If the coefficient of kinetic friction between the box and ramp is 0.26, calculate the change in the box’s kinetic energy.
gansta344u
25
An 85.8 N box of clothes is pulled 24.5 m up
along the ramp.
in the box’s kinetic energy. Answer in units
of J.
KE=1/2mv^2 ,Vf^2=Vi^2+2(a)(d),
PE= m g h
I tried to do a method told to me by a friend who said to use the formula
F d - m g d ( sin Θ - µ cos Θ) = 1/2 m v² but when i tried it it turned it to be wrong at least the way i tried it maybe it was a calculation error. Please help with concept and formula
That is a mean looking formula that might very well be the answer!
But you really should know how to figure it out from scratch.
Sketch the ramp with the force of gravity vector straight down from the box.
Resolve that vector into a component along the ramp and a normal force into the ramp.
Use trigonometry to find the two components.
Figure out the force of friction.
Then you can find the net force up the ramp and the work it does. It is that work that increases the KE.
I tired that, It is telling me that the answer is wrong for the problem as the answer i got 5362.063648J. If u can can u let me know if it was a calculation error
I got a very different answer - between 1000 and 2000. I'm not supposed to give answers here because it discourages people from doing their own work. Perhaps you could share some of your intermediate results. What did you get for the friction force? Parallel force?
for force of friction i got 20.81232745 and normal force as 80.04741329. i jus added up Ff + Fn+F after that i just multiplied Fnet by the distance and got 4342.259603
Ah, you need to take the direction of the forces into account when adding them!
Some are up the ramp and some are down the ramp.
so if i jus take into acount the force of friction is 20.812327146and subtract it from the force applied which is 118 i get 97.18767285. Then i just multiply it by the distance (24.5m) and i get 2381.097985 .is that rite or still kinda of
Oops, I missed noticing that you have Fn in there instead of the parallel force.
Fn is perpendicular to the ramp, so don't count it. But do count the component of the weight that is down the ramp. Add the 118N up the ramp. THREE forces to total. Yes, multiply the result by 24.5.
so the force of friction calculation and everything is right. But is the perpendicular force positive or negative. I know that i subtract 118-Ff but do i add the perpendicular force or subtract it. I am confuesd on that part
if i add the perpendicular force the awnser is going to be close to 4000.00N and u said u got a ans between 1000 -2000 . If i subtract the perpendicular force i get 419.9430147 which below ur score that said was tht u got. SO i am confused now
Have you got a diagram? It should show two arrows going down the ramp and only the 118 N arrow going up the ramp. One of the downs is the force of friction. The other is the parallel force - weight*sin(21.1). The perpendicular or normal force is NOT included here because it is perpendicular to the direction of motion. Only the forces in the direction of motion are counted when we consider the motion.
did u get 1624.348687 as the change in KE
That's it! Better round to 1620 or 1624 because you only had 3 digit accuracy in the given numbers.
What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is dependent on an object's mass and velocity, and is calculated by the equation KE = 1/2 * m * v^2.
How does friction affect kinetic energy?
Friction is a force that opposes motion, so it can decrease an object's kinetic energy by converting it into other forms of energy, such as heat or sound.
What factors affect the amount of friction between two objects?
The amount of friction between two objects depends on the types of surfaces in contact, the force pressing the surfaces together, and any lubrication or other substances present.
How is kinetic energy related to potential energy?
Potential energy is the energy an object has due to its position or condition. Kinetic energy and potential energy are interchangeable and can be converted into each other, depending on the situation.
How does kinetic energy play a role in everyday life?
Kinetic energy is present in many everyday activities, such as walking, driving a car, or throwing a ball. It is also important in machines and technology, as it is the energy that powers them.
