Kinetic energy and momentum of two objects
Two objects can have the same kinetic energy but different momentum, as demonstrated by a 5 kg mass moving at 50 m/s and a 125 kg mass moving at 10 m/s, both possessing 6.25 kJ of kinetic energy but differing in momentum (250 kg*m/s vs. 1250 kg*m/s). If both objects have zero momentum, it implies they are at rest, resulting in zero kinetic energy as well. The relationship between kinetic energy and momentum is defined by their formulas: kinetic energy (KE = 1/2 mv^2) and momentum (p = mv). Therefore, while kinetic energy can be the same for different masses and velocities, momentum is dependent on both mass and velocity. This discussion highlights the distinct nature of kinetic energy and momentum in physics.
wilmerena
do 2 objects that have the same kinetic energy necessarily have the same momentum? I can't think of a simple example
Consider a 5 kg mass going at 50 m/s, thus having 6.25 kJ of kinetic energy. Now, a mass of 125 kg going 10 m/s also has 6.25 kJ of kinetic energy. However, the first object has a momentum of 250 kg*m/s, and the second has 1250 kg*m/s of momentum.
thanks so much =o) !
what if they both have 0 momentum, so does it follow that the kinetic energy of the system doesn't have to be zero as well? or does it?
Think about it. For a simple object:
KE = 1/2 mv^2
momentum = mv
The only way an object can have zero momentum is if its speed (v) is what? Then what is its KE?
thanks again, i think i just spaced out on that one ;oP
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
