Kinetic Energy of a hydrogen electron
The discussion focuses on calculating the kinetic energy of a hydrogen electron using the Bohr model, with the given orbital speed of 2190 km/s. The kinetic energy formula KE = 1/2mv^2 is applied, but the user encounters an error in their calculations. They correctly convert the speed to meters per second and attempt to calculate the mass of a hydrogen atom but seem to confuse it with the mass of an electron. The user seeks clarification on the correct mass of an electron to accurately compute the kinetic energy.
physstudent1
In the Bohr model of the atom, the ground-state electron in hydrogen has an orbital speed of 2190 km/s. What is its kinetic energy?
KE = 1/2mv^2
I'm not sure what I am doing wrong but the program we use to enter homework is saying I'm wrong. So anyway kinetic energy = 1/2*m*v^2. Mass of 1 hydrogen atom = 1.008g/mol*(1mol/6.022*10^23 )*(1kg/1000g) = 1.674*10^-27 g/atom.
The speed is 2190km/s*1000m/km = 2190000m/s therefore
KE = 1/2(1.674*10^-27)(2190000)^2 = 4*10^-15 Joules
It asks for the kinetic energy of the electron. What is the mass of an electron?
