Kinetic Friction Coefficient Problem
A block on a plank begins to slide at an angle of 26.5°, covering 3.10 m in 2.00 seconds, prompting a calculation for the kinetic friction coefficient. The acceleration was calculated using the kinematic equation, resulting in 1.55 m/s². The force equation was set up, leading to a derived expression involving sine and cosine components of the angle. Initial calculations yielded incorrect negative values for the friction coefficient, indicating potential errors in calculation or unit conversion. Ultimately, correcting for degrees and order of operations led to a confirmed correct value of 0.322 for the kinetic friction coefficient.
iamtrojan3
A block is at rest on a plank whose angle can be varied. The angle is gradually increased from 0 deg. At 26.5°, the block starts to slide down the incline, traveling 3.10 m down the incline in 2.00 s. Calculate the kinetic coefficent of friction between the block and the plank.
Uk = friction Coefficient
D = Vot + 1/2at^2
F= ma
kinetic Friction = cos(theta)*m*g*Uk
First i used the kinematic equation to solve for the acceleration,
3.1 = 0 + 1/2a(2)^2
a = 1.55 m/s^2
Then with the acceleration i got here pluged it in the F= ma to get,
F = m (1.55)
F = sin(theta)*m*g - cos(theta)*m*g*Uk
Notice the m cancels out so i get
Sin(theta)g-Cos(theta)*g*Uk= a
g = 9.8m/s^2
I plugged everything in, theta = 26.5, a = 1.55, g = 9.8 and solved for Uk
Uk turned out to be -.352 which is wrong and makes no sense... but nevertheless, .352 is also wrong.
Any idea on what i did wrong?
thanks for the help!
Maybe a calculation mistake?
Using
Sin 26.5 = .446
Cosine 26.5 = .895
I get a different answer.
The Sine component is larger than the observed acceleration, so it means that the result should be a positive value.
Check to see that you are not using radians on your calculator ... it's degrees. A common source of error.
Order of operation mistake... i got .322 which is correct.
Thanks again for your help!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
