Kinetic Friction ProblemNeed Help
A user is struggling with a kinetic friction problem involving a 32.0 kg box being pulled by a rope at a 54.5-degree angle. They initially calculated the normal force and friction but ended up with an incorrect acceleration of -1.59 m/s². The discussion highlights the importance of correctly analyzing the forces, particularly the components of tension in both the x and y directions. After re-evaluating their free body diagram, the user realized they misinterpreted the scenario, thinking the box was on a slope instead of a horizontal surface. This clarification led to a better understanding of the problem.
mixedtape_15
Kinetic Friction Problem..Need Help!
Okay...so I really think I'm doing this right..but the CAPA thing won't take my answer so there has to be something I'm doing wrong.
The Question is ...
A 32.0 kg box is being pulled along a horizontal surface by means of a rope that exerts a force of 265 N at an angle of 54.5o above the horizontal. The coefficient of kinetic friction between the box and the surface is 0.330. What is the acceleration of the box?
So I drew my free body diagram and I had the Normal Force and the Weight and cosine of the angle in the y direction and I had the kinetic friction (normal force times kinetic friction coefficient) and weight and sine of the angle in the X direction.
Then I worked it all out and I got
Fy = may
Fy = 0
N - W(cos54.5) = 0
N - mg(cos54.5) = 0
N = 32.0kg (9.81 m/s^2)(cos54.5)
N = 182.3
Fx = max
-fk + T - w(sin54.5) = max
T - (N x uk) - mg(sin54.5) = max
265 - (182.3 x 0.330) - (32kg)(9.81m/s^2)(sin54.5) = 32kg(ax)
then I solved It all and it worked out to be -1.59 m/s^2
but its saying its not right..so I'm confused beyond belief now.
so Please help me .. lol:confused:
Check your trig functions in calculating N.
I've switched the trig functions around and tried that answer but still nothing. and I'm almost positive I have my trig done right anyways...but thanks.
mixedtape_15 said:
I've tried this already but it didn't help..besides I'm almost positive that I have my trig done right.
So you're sure N - w \cos{54.5} = 0?
well there is no acceleration in the y direction so I guess it would have to be that.
Look at the x- and y-components of all the forces, and determine what you have.
\Sigma F_{x} = T_{x} - F_{f}
\Sigma F_{y} = N + T_{y} - mg
Why the cosine? Like I said, rethink your trig.
I didn't think you had to incorporate the tension into the Y direction...isn't it just in the X?
Re-read the question, and redraw your free body diagram. The surface is horizontal, but the rope is not.
There is certainly a y-component of the tension, and it alleviates some of the normal force.
okay I'll go do that and hopefully figure this out..thanks
Okay I just redid it and realized my stupid mistake. I thought that the box was on a slope..but then when I reread it I realized that the box was on a straight horizontal and it was the rope that was on the angle. Thanks a bunch! :D
