What Is the Coefficient of Kinetic Friction in This Physics Problem?
The problem involves pulling a 250N crate with a 50N force at constant velocity, leading to the calculation of the coefficient of kinetic friction. The frictional force is equated to the applied force, resulting in the equation 50N = coefficient x 250N. Dividing both sides gives a coefficient of kinetic friction of 0.2. The solution is confirmed as correct, indicating that the calculations are straightforward. Understanding this concept is essential for solving similar physics problems.
Spartan Erik
"A forward horizontal force of 50N is used to pull a crate, which weighs 250N, at a constant velocity across a horizontal floor. The coefficient of kinetic friction is:"
Frictional force = coefficient of kinetic friction x normal force
This problem seems too easy, that's why I'm wondering if I might be wrong:
50N / 250N = coefficient
coefficient = 0.2
Is that all? Thanks
yup that is correct.
