Kirchhoff's current law and nodal analysis
The discussion focuses on using Kirchhoff's current law and nodal analysis to determine the current I in a given circuit. The user initially calculated a current of 35/22 A using Kirchhoff's voltage law but encountered issues when applying Kirchhoff's current law, resulting in contradictory equations. They derived four equations but ended up with a nonsensical value for I, which raised confusion. Other participants suggest clarifying the circuit diagram and ensuring the equations align logically. The consensus is that the problem is straightforward, and proper formulation of the equations is crucial for accurate results.
jonmondalson
Hello,
I'm looking to work out the current at I in the following circuit using Kirchoff's current law and nodal analysis:
[PLAIN]http://img853.imageshack.us/img853/4792/circuitgem.jpg
Using Kirchoff's voltage law (and loop analysis), I got a current of (35/22)A, but for the current law method I'm having problems.
I obtained the following equations using Kirchoff's current law:
4i1+2i2+4i3=5
-4i3-2i4=-10
and nodal analysis:
-i2+i3-i4=0
i1+i4=I
But solving these 4 equations produces a value for I of 0, which doesn't make sense, let alone agree with the answer using the other method.
Any help will be greatly appreciated.
Thank you
I got as far as your first equation and have no idea how you got it. (Actually, I think I know, but it's nonsensical)
Try drawing the I's and V's out on the diagram and writing equations that make sense.
It's a VERY straightforward problem.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
