How Do Elevator Accelerations Affect Weight Measurements?
In summary, the conversation discusses a physics lab where a spring scale was used to measure weight in an elevator. The maximum and minimum readings on the scale were recorded while the elevator went up and down. The conversation then poses two questions regarding the acceleration rates of the elevator and how it would affect the scale readings if the elevator's safety brake failed. Lastly, the conversation discusses the concept of frames of reference and how conducting the experiment in a non-inertial frame (the accelerating elevator) affects the perception of gravitational field strength. The conversation encourages drawing force diagrams and considering coordinate systems to properly calculate the force exerted on the scale.
rlechich
I'm stuck on some lab questions I have to answer in my physics class.
In the lab we held a spring scale in an elevator. We recorded his weight of the scale to be 9.5 Newtons. We rode the elevator up and down and recorded the maximum and minimum readings on the scale. The maximum reading up was 11 Newtons and the minumum was 8 Newtons. The Maximum reading down was 10 Newtons and the minimum reading dwon was 9 Newtons.
1) Estimate the maximum acceleration and deceleration rates of the elevator from your results obtained using the spring scale.
2) If the elevator cables broke and the safety brake failed such that the elevator's acceleration down is equal to "g", what should you expect the scales to read?
3) If you measure or weigh an object or time an event here in the laboratory then we say that those measurements are conducted in the lab frame of reference. For most purposes we can consider the lab at rest or moving with uniform velocity through space. Galileo said these two conditions are equivalent and Newton said the results predicted by his laws are the same in either event. We see all reference frames moving with unifrom velocity inertial or Galiean frames. You just conducted an experimetn in a non-inertial frame--the accelerating or decelerating elevator. Discuss how this affected you perception of the gravitational field strength in the elevator.
I'll try to get you started without giving you the whole answer.
consider what it is a spring scale measures:
W = mg
Now, draw force diagrams of the accelerating elevator, be sure to set up a consistent coordinate system, show the acceleration of the elevator and the acceleration due to gravity.
The Earth is exerting a force and the elevator is exerting a force, combine them to get something like f=(a+g)m.
Note that you will need to consider your coordinate system to get the above equation correct. (ie, that + sign may not be what you want.)
1) To estimate the maximum acceleration and deceleration rates of the elevator, we can use the equation F = ma, where F is the force measured by the spring scale and m is the mass of the elevator. The maximum acceleration can be calculated by dividing the maximum force (11 N) by the mass of the elevator, and the maximum deceleration can be calculated by dividing the minimum force (8 N) by the mass of the elevator. The values obtained will be in m/s^2.
2) If the elevator's acceleration down is equal to "g" (9.8 m/s^2), we would expect the scales to read a force of 0 N. This is because the elevator and the objects inside it would be in a state of free fall, and therefore, there would be no contact force between them. This is assuming that the scales are not attached to the elevator and are also in a state of free fall.
3) In the non-inertial frame of the accelerating or decelerating elevator, we would perceive a different gravitational field strength compared to the lab frame of reference. This is because in a non-inertial frame, there is an additional pseudo force acting on objects, which is caused by the acceleration of the frame itself. In this case, the pseudo force would be directed opposite to the direction of acceleration and would make us feel heavier or lighter depending on the direction of acceleration. This demonstrates the importance of considering the frame of reference when making measurements and observations in physics.
1. How does an elevator work?
An elevator works by using a motor and a system of pulleys to move a cab up and down along a track. The motor turns a pulley, which is connected to a cable that is attached to the cab. As the motor turns, the cable is wound or unwound around the pulley, causing the cab to move.
2. What safety features are in place for elevators?
Modern elevators have several safety features, including emergency brakes, limit switches, and safety gears. These features are designed to prevent the elevator from falling or moving too quickly, and to stop the cab in case of an emergency.
3. How are elevators powered?
Elevators are typically powered by electricity, either from a power grid or from a backup generator. Some newer elevators also use regenerative braking, which helps to conserve energy by using the motor to generate electricity when the elevator is descending.
4. What is the maximum weight limit for an elevator?
The maximum weight limit for an elevator varies depending on its size and capacity, but it is typically around 2,500 to 5,000 pounds. This weight limit is important to follow for safety reasons and to prevent damage to the elevator.
5. How do elevators know where to stop?
Elevators use a system of sensors and controls to determine where to stop. When a passenger presses a button to select a floor, the elevator's computer system calculates the best route to take based on the location of the cab and the requested floor. Sensors in the cab then detect when the elevator has reached the correct floor and signal the doors to open.
  • Classical Physics
  • Mechanics
9K
