Solving 2 Body Problems with Tension: Lack of Teacher Guidance
  • Thread starter rwofford
  • Tags
    Teacher
In summary: That said, here is a quick summary of how to do this problem:1. Draw a free body diagram for the cube being accelerated.2. Calculate the forces acting on the cube.3. Use Newton's Second Law to find the friction force.
rwofford
My teacher gave me this problem but we haven't even gone over two body probles with tension...especially those where one object is going another direction...
1) The drawing shows a large cube (mass = 21 kg) being accelerated across a horizontal frictionless surface by a horizontal force P. A small cube (mass = 2.1 kg) is in contact with the front surface of the large cube and will slide downward unless P is sufficiently large. The coefficient of static friction between the cubes is 0.71. What is the smallest magnitude that P can have in order to keep the small cube from sliding downward?
I don't know where to begin...are there any sites that would be helpful to someone who has not been taught how to do these types of problems...?
What is the magnitude of the force downward on the small front cube? What is the magnitude of the retarding frictional force upward due to the acceleration P?
isnt the acceleration of the large and small cube the same..? but they don't tell me the acceleration...
You're supposed to calculate the acceleration P where the front cube (yes, accelerating at P also) has its gravitational force down and its frictional force up balancing. Write the two equations for those two forces, and set them equal and see if that solves P for you. Let's see the work.
Gotta go. Good luck!
One has to calculate the horizontal force P which produces an acceleration.
P acts on the large and small cubes. The objective is determine the acceleration for which friction between small and large cube will prevent the small cube from falling.
So gravity pulls down the small cube, and the friction force operates vertically (in opposition to gravity). The friction force is simply the static coefficient * normal force which is simply the mass * acceleration.
The force P accelerates the large block against the small block, which also must be accelerating at the same rate for both to move together. But remember, mass resists acceleration or change in momentum.
Fg=mg
=21(9.8)
=205.8 N
=(2.1)(9.8)
=20.58
so i know: Ns * Fn = ma
0.71*Fn=205.8N(a)
i might as well give up...i am horrible at physics
Hint 1: What is the only force supporting the weight of the small cube? (Astronuc gave you this one.)
Hint 2: Use that fact to calculate the required normal force between the two cubes.
Hint 3: Use that fact to determine the resulting acceleration of the small cube.
That's enough hints for now! Solve it algebraically (using symbols) as much as possible--don't be in a rush to plug in numbers.
the normal force=mg
so : 2.1(9.8)=20.58 N
so : 0.71(20.58)=ma
so : 14.6118=ma
rwofford said:
the normal force=mg
No, the friction force equals the weight.
do i plug in 2.1 or 21 for m?
Any effort is wasted unless you begin by drawing the free body diagrams for all the objects in the problem.
We are talking about the smaller cube, so use its mass.
Gokul speaks truth--do as he advises.
so : 14.6118 = 2.1a
so : 6.958 = a
i think ill give up now...i am dumb..............................
is this right/?
No, it is not.
You need to start at the beginning. Follow these steps EXACTLY:
1. Draw and label the forces acting on the little block.
2. Write down the net force (sum of all forces) acting in the vertical direction, and the net force acting in the horizontal direction. Use symbols to represent various quantities. Save the actual numbers for the very end.
3. Write down Newton's Second Law for each of these two directions, and plug in the expressions for the net force and acceleration in each direction.
Do these steps here, and we'll see how it goes...
How does one use the 'coefficient of friction', [itex]\mu[/itex]? What is the relationship between friction and normal force?
This part is correct - the weight (or gravitational force) of the small block.
=(2.1)(9.8)
=20.58 N (One should write units)
Now one must determine the vertical friction force, which is proportional to the normal (horizontal) force, which is proportional to the acceleration of the small block.
That acceleration comes from the force P acting on both blocks.
I recommend doing as Gokul suggested with the force diagrams, and please refer to the steps mentioned by Doc Al.
1. What is a 2 body problem with tension?
A 2 body problem with tension is a physics problem that involves two bodies connected by a string, rope, or other elastic material. The tension in the string is an important factor in solving this problem.
2. Why is teacher guidance important in solving 2 body problems with tension?
Teacher guidance is important because these problems can be complex and require a solid understanding of physics principles and mathematical equations. A teacher can provide helpful tips and strategies for tackling these problems.
3. What are some common mistakes students make when solving 2 body problems with tension?
Some common mistakes include not correctly identifying all the forces acting on the bodies, incorrectly setting up the equations, and not considering the direction of the tension force in relation to the motion of the bodies.
4. How can I improve my skills in solving 2 body problems with tension?
Practice is key in improving your skills. Make sure you have a strong understanding of the physics concepts and equations involved in these problems. Also, try to solve a variety of problems with different scenarios and levels of difficulty.
5. Are there any online resources that can help with solving 2 body problems with tension?
Yes, there are many online tutorials and practice problems available that can help you improve your skills in solving 2 body problems with tension. You can also find instructional videos and interactive simulations to aid in your understanding of the concepts.
10K
