How to Handle Constraints in Lagrangian Mechanics?
The discussion focuses on formulating a constrained Lagrangian in polar coordinates for a system constrained to a curve defined by r = r(ψ). The proposed constrained Lagrangian is Lc = L(ψ, r, r') - λ(r - r(ψ)), which is deemed valid as it introduces a generalized force to enforce the constraint. A further complication arises when a parameter "a" is introduced, which becomes a function of r under the constraint. The key question is whether to incorporate this dependency in the constrained Lagrangian or to solve the Euler-Lagrange equation without considering a(r). The participants agree that the formulation makes sense and provide insights into handling the dependency of "a" in the equations.
Sunfire
Hello,
I have the functional
J = ∫ L(ψ, r, r') dψ, where r'=dr/dψ. L is written in polar coordinates (r,ψ).
Now I want to constrain the motion to take place on the polar curve r = r(ψ). Can I write the constrained lagrangian as
Lc=L(ψ, r, r') - λ(r - r(ψ)) and then solve the Euler-Lagrange equation
Does this make sense?
Thanks!
You should probably call the curve something else, like ##\rho(\psi)##. But yes, you should be able to do that, the extra ##\lambda(r - \rho)## term will give you a generalized force constraining the object to the curve.
CompuChip said:
... yes, you should be able to do that, ...
Thanks CompuChip...
Along these lines - say, the Lagrangian is, as agreed, Lc = L(a, ψ, r, r') - λ(r - f(ψ))
where r=f(ψ) is the constraint and "a" is a parameter.
The question is - I know that when imposing the constraint, it so happens that a = a(r). I mean, "a" becomes a function of r under the imposed constraint.
This is a challenge... Do I write
Lc = L(a(r), ψ, r, r') - λ(r - f(ψ)) and then solve the Euler-Largange eq.; or do I solve the E-L eq. and not worry about a(r)? It's a puzzle. Would you or someone know?
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
