Lance Deal's Angular Velocity & Centripetal Force in Rotational Motion
Lance Deal's hammer throw at the Atlanta Olympics reached 81.12m, earning him a silver medal. The hammer, attached to a 1.21m cord, was launched at a velocity of 28.8m/s at a 35-degree angle. The angular velocity at release was calculated to be 14.4 rad/s. The centripetal force exerted to hold the hammer was determined to be approximately 3011N, which is equivalent to a mass of about 307kg when converted. This analysis highlights the physics behind Deal's impressive performance in rotational motion.
faoltaem
On his last throw of the Atlanta Olympics, Lance Deal launched the hammer 81.12m, good enough for a silver medal. The hammer is thrown by rotating the body in a circle, building up rotational speed until releasing it and letting the rotational velocity change to translational velocity. The hammer is affixed on the end of a 1.21m long cord and along with the arms makes for a radius of rotation of 2.00m. Knowing that the hammer is launched at an angle of 35.0 degrees to the horizontal, we can use projectile motion equations to calculate that the hammer is launched with a velocity of 28.8m/s.
a) What is Lance Deal’s angular velocity as he releases the hammer?
b) The ball of the hammer weighs 7.26kg. What centripetal force was Lance exerting to hold onto the hammer?
c) Convert the centripetal force to its equivalent in mass if you were holding it in your hand.
v = r\omega
\frac{\Delta\omega}{\Delta t}
\omega = \frac{d}{\Delta t}
\overline{\alpha} = \frac{\Delta\omega}{\Delta t}
a_{cp}=r\omega^{2}
w_{f}^{2} = w_{o}^{2} + 2\alpha\theta
v_{f}^{2} = v_{o}^{2} + 2ax
i'm finding it a little bit hard to get started on this question because all of the relavent equations that i have either have time or a form of acceleration in them and i haven't been given either of these. would it be possible for someone to tell me what equation they would use for (a), and then i should be able to work them all out cause the questions are kind of flow on.
Hi
You already wrote down more equations than needed.
a) v=r*\omega \Rightarrow \omega=\frac{v}{r} with given velocity v (=28.8 m/s) and r (=2m) you can easily calculate the angular velocity \omega,
b) Centripetal force F_{z}=\frac{m*v^{2}}{r}=m*r*\omega^{2}
I hope this helps you a bit...
Yannick
thanks i didn't realized i'd overlooked that information
so:
a) \omega = \frac{v}{r} = \frac{28.8}{2} = \underline{14.4rad/s}
b) f_cp = ma_cp = \frac{mv^{2}}{r} = mr\omega^{2}
= 7.26 x 2 x 14.4^{2}
=3010.8672 = \underline{3.01 x 10^{3}N}
c) F=mg F=f_cp = 3011N, g=9.81m/s^{2}
m=\frac{F}{g} = \frac{3011}{9.81} = 306.918
=\underline{307kg}
