How Oranges Exist Under Thermodynamics Laws
wallz
hey, i had this question for homework:
How oranges( which have structured objects) can exist given the laws of thermodynamics?
i have no idea how to answer this, so any help is greatly appreciated
When I boil some water, at first the water is silent, but then convection starts: a very structured mass movement of particles appears spontaneously. Shouldn't the second law forbid this? After all, a disorganized mass of water molecules all decide to move coherently! The answer is no, even more so, the second law also likes it! After all, what is the result of convection? Convection is for heat transfer (a better word is "energy dissipitation"); so although the convection itself is a very organized structure, its role is to increase entropy faster (heat gets distributed faster with convection than without it), so in this process entropy production increases and does not decrease.
How does this relate to oranges? Maybe the whole concept of life is just one big spontaneous convection: organized structures that simply accelerate the production of randomness
okay i just want to ask you , because i think i have grasp of what the answer is and your input helped alot.
so assuming that the world is a closed system that would mean that the entropy of the world is always increasing or stays the same
also keeping in mind that entropy is an expression of the randomness or disorder
as well as that energy flows from hi temperature areas to low temperature ones.
So if the worlds entropy is increasing then the randomness and disorder is increasing, while the energy is moving from its high temperature areas to the low ones, since orange molecules are not closed system and assuming that their entropy decreases, the energy flowing to the low temperature areas is able to make oranges exist since the entropy is decreasing for those molecules hence the disorder is decreasing so the molecules can pull together or stay together?
does that seem right?
i know some of it might be wrong, but I am really bad at physics at the university level, maybe because of the how quick lessons go i don't catch on quick enough
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
