Laws of thermodynamics compared with life.
The discussion explores the analogy of the laws of thermodynamics as a game, where the first law indicates energy conservation, meaning energy cannot be created or destroyed. The second law highlights that efficiency is limited, with Carnot's theorem defining the maximum efficiency achievable. The third law relates to entropy, suggesting that systems tend toward disorder and ultimately a state of heat death. Participants express confusion over the analogy's clarity and its cultural relevance, concluding that it may not effectively translate across different contexts. Overall, the conversation emphasizes the fundamental principles of thermodynamics while questioning the usefulness of the analogy.
gianeshwar
Dear friends! I had read about a comparison of laws of thermodynamics as follows.
" If energy extraction is a game.
First law: You cannot win the game.
Second law: There is no break even.
Third law:You can not leave the game".
My problem is that I cannot convincingly understand the comparison.
Please tell me how each of them matches with the actual corresponding statements in Physics Text Books.
Science news on Phys.org
I think, about first law, you can't win the game as there's no new production of energy to be extracted but just the same energy transforming into different forms.
Cultural analogies are only marginally useful within the originating cultures; they seldom translate well. Bottom line, it ain't worth worrying about it.
Actually, I think it goes:
You can't win; you can only break even.
You can't break even.
You have to keep on playing.
First law is conservation of energy.
Second law is about efficiency. With Carnot showing the maximum available.
Third law is about entropy and heat death of the universe ( I think )
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
