Learning Fluid Power Systems for University Final Year Project
  • Thread starter Thread starter bill nye scienceguy!
    Hydraulics Textbook
A university student is seeking recommendations for textbooks on fluid power systems for their final year project involving a new hydraulic pump. A suggested resource is "Introduction to Fluid Power" by James L. Johnson, which is noted for its clear explanations and helpful diagrams that differentiate flow types. An older Eaton/Vickers text is also praised for its comprehensive coverage of fluid power components. The student appreciates the visual aids that simplify understanding of pressure and return flows. The discussion emphasizes the importance of solid foundational knowledge in fluid power systems for successful project execution.
For my university final year project I'm going to be working with a spin out company who are developing a new type of hyrdualic pump. However, my knowledge of fluid power systems is minimal at best, so can someone recommend me a good textbook so i don't look like a total numpty when I start?
Introduction to fluid power by James L.Johnson ( DELMER -a division of thompson learning.inc)
I have an older copy of this Eaton/Vickers text and it is really good at explaining all of the various types of components you would ever see. I like the diagrams because they color the various flows with different colors so it is easy to pick out areas like the pressure and return sides.
https://www.amazon.com/dp/0963416200/?tag=pfamazon01-20
thanks guys, i'll check them both out
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
