Lenses and Autocollimation: Altering Focal Length and the Lensmaker's Equation
  • Thread starter Thread starter reb659
    Lenses
In the autocollimation experiment, a thin convex lens is positioned 25 cm from a pinhole light source, with a plane mirror 20 cm behind it, creating a sharp spot beside the pinhole. The focal length of the lens can be determined using the lensmaker's equation, but the initial attempt was incorrect. To increase the focal length of a symmetrical biconvex lens, the lens should be made rounder, resembling a sphere, rather than flatter. The relevant equations include 1/o + 1/i = 1/f and (n-1)(2/r) = 1/f, with adjustments made for the biconvex shape. Understanding these principles is essential for solving the homework problems accurately.
reb659
a) In the autocollimation experiment of Sec. 3.5, a thin convex lens is placed 25 cm from a pinhole that acts as a point source of light. A plane mirror placed 20 cm behind the lens reflects the light back through the lens, and the reflected light forms a sharp spot beside the pinhole.
What is the focal length of the lens (in cm)?
b) Consider a symmetrical biconvex lens with r1 = r2 = r
How would you alter the lens if you wanted to make the focal length longer?
Make it flatter (more like a flat slide) or make it rounder (more like a sphere)?
A. 1/f = 0
B. 1/f = 2(n - 1)/r
C. 1/f = 2(1 - n)/r
D. 1/f = (n - 1)/r
1/o+1/i=1/f
(n-1)(2/r)=1/f
a)I used the lensmaker's equation but the answer was wrong. Shouldn't this formula apply?
b) Increasing the focal length would occur if the radius was increased. Since it is a biconvex lens, they will increase if the lens is made to go outward more, such as if it was a sphere instead of flat.
Something tells me that I know you :)
Anyway
for (a) Read page 42, section 3.1.2 in your physics lab book
for (b) use equation 3.2 (see below)
(n-1)(1/r' -1/r'') = 1/f
for a biconvex lens, r'' is negative
hence (n-1)(1/r' - 1/-r'') = 1/f
(n-1)(1/r' + 1/r'') = 1/f
but since r' = r'' = r, substitute and solve and you'll get your answer
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
