Lets say you have a system with four capacitors(c1,c2,c3,c4)
  • Thread starter Thread starter eyehategod
    System
The discussion revolves around a circuit with four equal capacitors (1F each) arranged in series and parallel configurations. Capacitors c1 and c2 are in series, as are c3 and c4, with the resulting combinations (c12 and c34) placed in parallel. The equivalent capacitance of the entire system is equivalent to one of the capacitors alone. The conversation highlights the advantages of this configuration, although specific benefits were deleted by a moderator. The thread emphasizes the importance of posting homework questions in appropriate forums.
eyehategod
lets say you have a system with four capacitors(c1,c2,c3,c4) all equal to 1F.
c3 and c4 are in series
c12 and c34 are in parallel
c1 c3
c2 c4
c1234(equivalent capacitance) has the equivalence of one of the capacitors by itself. What advantage would there be to having a system in this combination?
You get a capacitor with << answer deleted by berkeman >>.
This is a homework/coursework question, so I am moving it to the Homework Help forums, and I deleted the answer given (although the OP probably already received the text of the answer via PM if he has that notification turned on).
eyehategod, you need to stop posting homework/coursework questions in the general technical forums.
c1 c3
c2 c4
Well, when you get back from your temporary ban, what would you think the advantage would be?
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
