How Do You Choose the Correct Form for L'Hospital's Rule with Products?
  • Thread starter Thread starter PFuser1232
PFuser1232
To deal with the indeterminate form ##0⋅\pm \infty##, we write the product ##f(x)g(x)## as ##\frac{f(x)}{1/g(x)}## or ##\frac{g(x)}{1/f(x)}##, before applying L'Hospital's rule to one of these forms.
However, on occasion, applying L'Hospital's rule to one of these forms gets us nowhere (##\lim_{x \rightarrow -\infty} x e^x## for instance), despite working for the other (equivalent) quotient.
Is there a way to know beforehand whether ##f(x)g(x)## should be expressed as ##\frac{f(x)}{1/g(x)}## or ##\frac{g(x)}{1/f(x)}##? Or is it always based on trial and error?
I think there is some intuition needed. Usually, any function that can be reduced away should be in a position to allow that to happen, as in your example x exp(x).
By leaving the polynomial part on top, you can be sure that application of L'Hopital's rule will eventually reduce that away.
Other than that, I think guess and check until you've done enough...then educated guess and check.
Likes PFuser1232
You can write ##x e^{x}## as ##\frac x {e^{-x}}##. In that form you have the form ##[\frac{-\infty}{\infty}]##, so L'Hopital's Rule can be applied.
Likes Emmanuel_Euler
