Solving Light & Dispersion: Angle of Incidence of Blue Light
  • Thread starter Thread starter Deidre
    Dispersion Light
The discussion revolves around calculating the angle of incidence for blue light striking flint glass, given that yellow light strikes a diamond at a 47.0° angle of incidence. The refractive indices for yellow light in diamond and blue light in flint glass are provided as 1.523 and 1.531, respectively. The initial approach incorrectly mixed equations, leading to confusion in solving for the angle. The correct method involves setting up two equations based on Snell's Law, allowing for the determination of the angle of incidence in flint glass. The conversation emphasizes the importance of correctly applying the equations to solve for the desired angle.
Deidre
Yellow light strikes a diamond at a 47.0° angle of incidence and is refracted when it enters the diamond. Blue light strikes a piece of flint glass and has the same angle of refraction as does the yellow light in the diamond. See Table 26.2 for data. What is the angle of incidence of the blue light?
Table 26.2
Approx. Color>Wavelength in Vacuum (nm)>Index of Refraction, n
Yellow>580>1.523
Blue>470>1.531
sin(angle1)n1=sin(angle2)n2
sin(47)*(1.523)=sin(angle)*(1.531)
sin(angle)=.7275321
angle=46.6799
Argh, thought I knew what I was doing, apparently not :mad: :frown:
First, I assume that the 1.531 is the index of refraction of blue light in flint.
You have mixed the equations.
let x be the angle of refraction for both the diamond and the flint
let y be the angle of incidence in the flint.
sin(47)=x*1.523 for diamond
and
sin(y)=x*1.531 for flint
You now have 2 equations and 2 variables which you can solve.
