Light clock with spaceship moving vertical at .99c
ebodet18
So what would happen if there was a spaceship moving at 99% the speed of light straight up. The spaceship has a light clock, so a photon of light moving bouncing between 2 mirrors in such a way that the light moves ALMOST in sync with the spaceship moving up. In theory wouldn't the light photon move very very slowly up to the top mirror and back to the bottom. Would time be almost come to a complete stop?
Welcome to PF!
To answer your question:
It seems that way but not really! - Why?
Lights speed is absolute, meaning, it always travels at the speed of light relative to EVERY viewpoint. So...If you were moving at .99 c, and you saw a photon, that photon would STILL be moving 300,000 m away from you every second. THIS is why time and space stretch in relativity. Since C was absolute, Einstein saw that if the speed of light was ALWAYS the speed of light, something else had to give (i.e space and time) In order for it to make sense that a photon would still be traveling away from you at 300,000 m/s if you were traveling .99% of c, Einstein postulated that you the observer would need to experience time much slower in order for this to occur. Hope that helps!
Ahh that's interesting! Thanks for the quick answer!
No problem! Relativity is fascinating
Assuming the spaceship's light clock is oriented in the usual manner--parallel to the direction of travel--then the light would be moving just slightly faster than the mirror as the light traveled from bottom to top. So as observed by you on Earth (if you could make measurements of the light's travel between mirrors) the light would cover that distance rather slowly. (The speed of light is the same, but the mirror is moving away from the light.) But during the reverse trip (from top back to bottom) the light would be moving towards the oncoming bottom mirror. So from your viewpoint on earth, the travel time going up is greater than the travel time going down.
Of course from the viewpoint of the people in the space ship, everything would work normally.
No. While the "ticking" of that moving light clock would be slow as observed by you, it only slows by a factor of about 7.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
