Electrical Why Do Some Sections of My Pre-Lit Christmas Tree Not Light Up?
  • Thread starter Thread starter Office_Shredder
    Lights Tree
The discussion revolves around troubleshooting a pre-lit Christmas tree with two non-functioning branches. The tree features a wiring system where each section has a power strand connected to splitters that distribute power to the bulbs. The user suspects that the splitters may be faulty, potentially causing the lights to fail. There is uncertainty about whether the green tab on the splitter is designed for disassembly or if attempting to manipulate it could cause further damage. To diagnose the issue, it is suggested to use a digital voltmeter (DVM) in AC voltage mode to check if the bulbs are receiving the correct voltage. It's noted that even if a bulb is not lighting, it may not necessarily indicate a break in the circuit, as some bulbs have a parallel wire that can short the circuit without glowing. Additionally, the concept of fuses and anti-fuses in the bulb wiring is introduced, emphasizing the importance of understanding these components before attempting repairs.
Office_Shredder
Staff Emeritus
TL;DR Summary
I have a very expensive Christmas tree with two dead branches that drive my wife crazy. Help save my christmas!
I have a Christmas tree that's pre-lit. The basic setup is each section of the tree has power, and a strand of wire that comes out and wraps around the tree. That strand passes through a bunch of green plastic connector things, which appear to be a splitter of some sort - the strand goes in and then out of one end, and on the other end another wire comes out that powers all the bulbs for the branch. The splitters have a little green tab that looks like you are supposed to push it, and then something happens though I have no idea what.
I attached a couple pictures that hopefully illuminate the situation.
So I have two branches out of like, 100 that are dead. My theory is that the connector/splitter things are junky- either it shorted, or disconnected internally, or something. I'm worried about breaking the other 98 branches worth of lights doing anything though. So I guess my question is, can I actually disassemble this green splitter and try to rewire this in a way that isn't a horrible idea? In particular is the little tab actually intended to be a way of assembling/ disassembling, or am I just going to break it trying to push the tab and pull the wires?
I don't know what I'm looking at in those pics.
[ EDIT ]
OK, I see .
These Christmas string light problems can be frustrating, as you now know.
I would try these two things in order at first:
** [redacted, dumb non-applicable idea]
** use my DVM in AC voltage sense mode to figure out if the bulbs should be getting AC voltage or not. If you don't know how to do that, just ask and we can guide you.
I think berk is wise. I'd look a the standard causes for string light failure before opening up closed components.
Note: these bulbs have two wires inside, one that glows (and it can burn out) and one (in parallel) that just shorts the circuit. So even if the bulb doesn't light up doesn't mean that's where the circuit is broken (although the working ones definitely don't break the circuit).
Fuse. The normal voltage across the un-fused bulb is only a few volts.
Anti-fuse. This one is coated with an insulating material that breaks down and shorts once the voltage reaches a suitably high voltage. It is only electrically connected to the circuit once that happens.
BoB
Likes berkeman, Borek and Tom.G
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
Hot Threads
