Limits of Differential Equations
The discussion focuses on finding the limit of the differential equation (dx/dt) = k(a-x)(b-x) with the initial condition x(0)=0. For part a, where 0<a<b, the user attempts to solve the equation but encounters difficulties and believes the limit as t approaches infinity is a, although they cannot prove it. In part b, where 0<a=b, the user seeks clarification on the solution process and the validity of their calculations. Other participants suggest checking the initial solution and correcting any errors in the exponent manipulation. The conversation emphasizes the importance of verifying each step in solving differential equations.
olive.p
I need help finding the limit of the differential equation.
(dx/dt) = k(a-x)(b-x) that satisfies x(0)=0
assuming
a) 0<a<b and find the limit as t->infinity of X(t)
b) 0<a=b and find the limit as t->infinity of X(t)
none
I separated the equation in part a and attempted to solve for x and got a nasty equation
http://www4b.wolframalpha.com/Calculate/MSP/MSP115222ac5cd5fd1ghhf0000016hfg120ch979ad9?MSPStoreType=image/gif&s=20&w=156.&h=41. then I solved for c and found it to be c=-(a/b). I plugged that in for c and got:
http://www4f.wolframalpha.com/Calculate/MSP/MSP49220eh2769a9a2d53700001g9fiib9hd1eh2c3?MSPStoreType=image/gif&s=49&w=159.&h=50. I don't know how to take it further.
I believe that the answer to part a is a based of a graph, but I am unable to prove it.
Thanks in advance.
assuming
none
Thanks in advance.
Did you check the solution you got for x in your first equation above?
The last equation is wrong. Why did you change the second exponent?
You can replace ## e^{akt} e^{-bkt } = e^{(a-b)kt } ## in the first equation. The value c=-a/b is right. Just plug in for c.
Never mind I had it right early. Thanks anyway everyone!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
