Why Does Reversing Limits of Integration Affect the Answer?
Miike012
My limits of integration for my angle I chose to be from pi to 0 then I got the negative answer from what was in the book.. Shouldn't that be correct because we are integrating from -3 to 3?
What did you get for your answer? I got a positive value for the integral, a tad over 3.
when I integrated from pi to 0 I got 1/2pi(cos(9) - 1)
That should be -(1/2)pi *(cos(9) - 1). The antiderivative of sin(u) is -cos(u).
So it is correct to integrate from pi to 0?
It's correct to integrate from 0 to pi, like so:
$$ \int_{\theta = 0}^{\pi} \int_{r = 0}^3 sin(r^2)r~dr~d\theta$$
Is that what you meant? If you meant ##\pi## as the lower limit of integration, and 0 as the upper limit, you'll get the opposite value.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
