Deriving Electric Field in y-direction from Line Charge of Lambda=4.5 nC/m
swain1
A line charge of liner charge density lambda=4.5 nC/m lies on the x-axis and extends from x=-5cm to x=5cm. Derive an expression for E_y.
I have started with this question and it seems that I have to sum the electric fields in the y direction caused by each dx along the line with a charge dq. I think I understand how to do the integral but I just don't know what the field in the y direction is? Thanks for any help.
Just imagine that the apparent charge, when 'felt' from test charges away from the rod convene to a equidistant point on both sides of this rod. Consider this to be the y-distance away from the x-axis (rod). Since this rod is of finite length, then you should approximate the greatest electric field to be at x=0, and then at some distance y from the bar. Now, all you have to do is find how far away from y=0 the electric field maximizes. You can simply triangulate to find this point, and then use vector addition of the j-components from the two integrals.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
