Linear Algebra Composition Isomorphism Question
Nexttime35
Let S : U →V and T : V →W be linear maps.
Given that dim(U) = 2, dim(V ) = 1, and dim(W) = 2, could T composed of S be an isomorphism?
If Dim(v) > dim(W), then T is 1-1
If Dimv < dim(w), then T is not onto.
So this seems like a tricky question, but I am having trouble proving whether or not this is an isomorphism. While I know that T composed of S (u) = T(S(u)), S: U→V and T:V→W, this would be an isomorphism if dim(U) = Dim(W). But does the fact that S maps to V, which is one dimension less than U and W, affect that this is an isomorphism?
I think an example could be helpful in helping me understand this problem.
Thank you.
That should read "If Dim(V) > Dim(W), then T is not 1-1". I'm sure that's what you meant, but just making sure.
Anyway, let's suppose that TS is an isomorphism. Which would mean that given w \in W, there is a u \in U. Such that TS(u) = w. Is this a problem?
That makes sense, kduna, thank you. So Basically this composition bypasses the use of V, and there exists an isomorphism from U to W. Thanks.
Actually no. w = TS(u) = T(S(u)). So w \in Range(T). But this can be done for any w \in W. This would mean T is surjective, a contradiction since dim(V) < dim(W).
Therefore TS cannot be an isomorphism.
Note that since dim(U) = 2 = dim(W), an isomorphism does exist between U and W. But TS is not an isomorphism.
Ahh, I see. That makes much more sense. Thank you for your help, kduna.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
