Linear Algebra: Find all axioms that fail k(a,b)=(ak^2,bk^2).
sbguitar
If we define V as the set of vectors in R^2 with vector addition defined as it normally is, but scalar multiplication defined to be k(a,b)=(k2a,k2b), then V is not a vector space. Find all axioms that fail (and explain why they fail).
Axioms:
1. If u and v are objects in V, then u+v is in V.
2. u+v = v+u
3. u+(v+w)=(u+v)+w
4. There is an object 0 in V, called a zero vector for V, such that 0+u=u+0=u for all u in V.
5. For each u in V, there is an object -u in V, called a negative of u, such that u+(-u)=(-u)+u=0.
6. If k is any scalar and u is any object in V, then ku is in V.
7. k(u+v)=ku+kv
8. (k+l)u=ku+lu
9. k(lu)=(kl)u
10. 1u=u
I couldn't figure out how to start.
If addition is defined as normal, and scalar multiplication is altered, that gives you a hint on what axioms to check.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
