LINEAR ALGEBRA: How to prove system has one unique solution
phyzz
Show that the system ∑ hereunder admits one unique solution
<br /> ∑ =<br /> \left[\begin{array}{cc}<br /> 1 &amp; a_{1} &amp; a_{1}{}^{2} &amp; a_{1}{}^{3} &amp; | &amp; b_{1}\\<br /> 1 &amp; a_{2} &amp; a_{2}{}^{2} &amp; a_{2}{}^{3} &amp; | &amp; b_{2}\\<br /> 1 &amp; a_{3} &amp; a_{3}{}^{2} &amp; a_{3}{}^{3} &amp; | &amp; b_{3}\\<br /> 1 &amp; a_{4} &amp; a_{4}{}^{2} &amp; a_{4}{}^{3} &amp; | &amp; b_{4}<br /> \end{array}\right]<br />
I know I have to perform Gauss-Jordan elimination fully by pivoting on the diagonal and zeroing out both on top and bottom of the diagonal.
After just two steps I'm stuck. I came up with this:
<br /> ∑ ∼<br /> \left[\begin{array}{cc}<br /> 1 &amp; a_{1} &amp; a_{1}{}^{2} &amp; a_{1}{}^{3} &amp; | &amp; b_{1}\\<br /> 0 &amp; a_{2} - a_{1} &amp; a_{2}{}^{2} - a_{1}{}^{2} &amp; a_{2}{}^{3} - a_{1}{}^{3} &amp; | &amp; b_{2} - b_{1}\\<br /> 0 &amp; 0 &amp; - &amp; - &amp; | &amp; -\\<br /> 0 &amp; 0 &amp; - &amp; - &amp; | &amp; -<br /> \end{array}\right]<br />
I don't know how to continue to fill in the _ spaces as I don't know what operation zeroed out the values under the pivot.
I don't like dividing the pivots through just so they're of value 1 as to avoid working with fractions.
I know I'm looking for a compatible system (i.e. (n - r) = 0, n being #rows and r being the rank) that also gives 0 secondary unknowns (i.e. (p - r) = 0, p being #columns not including the RHS and r = rank).
Thank you very much!
Why don't you calculate the determinant?
As stated the result is false; you need to assume something about the ai!
RGV
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
