Linear algebra proof with operator T^2 = cT
evilpostingmong
Let T:V--->V be an operator satisfying T^2=cT c=/=0.
Show that V=U\opluskerT U={u l T(u)=cu}
Now before I start, just one quick question about ker T:
U seems to be an eigenspace since T(u)=cu with c the eigenvalue.
But that must mean that the kernel has 0 as the only element since
0 is not an eigenvector so it can't be in the eigenspace, right?
And, since T^2=cT, c cannot be 0 otherwise we would have T(0).
Hi evilpostingmong! :smile:
(have a not-equal: ≠ and try using the X2 tag just above the Reply box :wink:)
T2 = cT means T is a projection …
so suppose eg V is R3, and T is the projection onto the x-y plane (with c = 1),
then kerT is the z-axis. :wink:
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
