How can we solve the ballistic pendulum problem using conservation of energy?
In summary, to solve this problem, we can use the principle of conservation of energy. Initially, the system's total energy is (1/2)mv^2 and after impact, it is (m+M)gh. By equating these two expressions, we can solve for the speed v.
fairuzjannah
A ballistic pendulum consisting of a heavy bob of mass M suspended form a fixed point by a thread of length l is at rest. A bullet of mass m and traveling horizontally at a speed v hits the bob and imbeds itself an the bob. As a result, the pendulum is deflected through a amaximum angle θ from the vertical. Show that
v = (M+m)/m √(2gl(1-cos⁡〖θ)〗 )
where g is the acceleration du to gravity ?
i really blind with this questions, anyone please i need an answer how to solve it..thaanks :)
Well, as you suggest in your title, you can use "energy"- specifically, conservation of energy. (I don't believe you need conservation of momentum.)
Initially, the mass Mis not moving so its kinetic energy is 0 and the mass m has speed v so its kinetic energy is [itex](1/2)mv^2[/itex]. We can take the potential energy to be 0 at the initial height of bullet and bob so the total energy is [itex](1/2)mv^2[/itex]. After impact, at the bob's highest point, both bullet and bob have 0 kinetic energy so the total energy is just the potential energy, (m+M)g h where h is the height the bob and bullet rise to. By conservation of energy, then, [itex](m+M)gh= (1/2)mv^2[/itex]. Solve that for v.
1. What is linear momentum?
Linear momentum is a physical quantity that describes the motion of an object. It is defined as the product of an object's mass and its velocity.
2. How is linear momentum conserved?
Linear momentum is conserved in a closed system, meaning that the total momentum of all objects in the system remains constant regardless of any internal or external forces acting on the system.
3. What is the relationship between force and linear momentum?
According to Newton's second law of motion, force is equal to the rate of change of linear momentum. This means that when a force is applied to an object, it will cause a change in its momentum.
4. What is the difference between elastic and inelastic collisions in terms of linear momentum?
In an elastic collision, the total linear momentum of the system is conserved, meaning that the total momentum before the collision is equal to the total momentum after the collision. In an inelastic collision, however, some of the kinetic energy is converted into other forms of energy, such as heat or sound, and the total linear momentum may not be conserved.
5. How is kinetic energy related to linear momentum?
Kinetic energy is the energy an object possesses due to its motion. In terms of linear momentum, the kinetic energy of an object is directly proportional to the square of its velocity, and the product of its mass and the square of its velocity is equal to its linear momentum.
