How Can I Design a Linear Power Amplifier for Frequencies up to 1MHz?
The discussion revolves around designing a linear power amplifier capable of driving low impedance coils at frequencies up to 1MHz. The original design faced issues with current regulation, leading to undesirable output waveforms when driving inductive loads. The user explored using a voltage-to-current converter but encountered bandwidth limitations, as the initial design could only handle frequencies up to 200-300 kHz before distortion became problematic. The user is seeking alternative amplifier designs that can operate effectively in the 100 kHz to 1 MHz range, as existing options seem limited. Ultimately, the goal is to create a reliable current-regulated AC power source for specific inductive applications.
Jdo300
Hello All,
I am faced with a very interesting challenge and I'd like to see if you all could give me any insights. I'm currently planning to design a linear power amplifier loosely based on the design on page 22 of this PDF file here: http://www.wadsworthmedia.com/marketing/sample_chapters/1401848567_ch05.pdf
So far, I have just been doing simulations of the circuit to get a feel for it's operation. However, I want to do a few things different with the design that are, at the moment, throwing me for a loop.
In my application, I am building an amplifier specifically for driving coils of varying inductances at frequencies from 0Hz to about 1MHz (up to 20MHz ideally, but I I'm settling for lower frequency for simplicity). I found that sticking an inductive load works fine with this amplifier design except for the fact that the amperage through the coil varies with frequency due to the coil's inductance.
What I am thinking about is modifying the schematic so that it doesn't utilize voltage regulation but current regulation to keep the coil current constant throughout the frequency range. So, in other words, I want to basically make this into a voltage to current amplifier, with, say 100mV on the input translating to 100mA through the output load.
To be more clear, I'm mainly going to be driving very low impedance coils, (0-5Ohms, ~10uH - 1mH max) at frequencies from DC to about 1Mhz or so. The maximum current I want to be able to source is about 1-5A max. To implement the current regulation scheme, I found this circuit from a Wikipedia page which shows how one can make a simple op-amp voltage to current converter:
http://en.wikipedia.org/wiki/File:I-to-v_op-amp_current_source_1000.jpg
I modified the amplifier schematic in the simulator to use the a 0.1 Ohm sense resistor for a current shunt in the feedback circuit. This allowed me to get an output of 1mA for an input of 1mV into the circuit. This *seemed* to work fine until I attempted to drive a given coil (100uH for example) at higher and higher frequencies. What I found is that the output current started to look more like a triangle wave than a sine wave, I saw that this happens because the feedback voltage was turning into a square wave in attempts to regulate the current, but due to the impedance of the coil, the current couldn't respond fast enough.
So I scrapped that idea and went back to the original schematic, which did produce a nice sinusoidal output, though the current varied with frequency. My next idea was to somehow come up with a feedback circuit that could increase or decrease adjust the output voltage across the coil to keep the current at a set amplitude but without the same issues that I was having with the other scheme. This seems like it shouldn't be that hard to do, but I have no idea how to approach this problem. Is their a better way to do this? Ultimately. what I am trying to make is a current-regulated AC power source.
Thanks,
Jason O
Going through some calculation using.
1 Amp, 10 microhenry, 1 megahertz
Xl=2*Pi*f*L
Xl=2*3.14*10^6*10^-5=62.8 ohm
E=I*Xl
E=1*62.8 Volt
So if you are talking about RMS volts, Peak volts will be 88.8 and peak to peak volts will be 177 volt.
So roughly speaking you require an operational amplifier using +100 VDC and -100 VDC
power supplies.
Of course higher inductance coils or higher currents will require even higher voltages.
Hi Carl,
Thanks for the info there, that's rather depressing to hear seeing as I want to use +-12V for the supply rails! Perhaps I'll shoot for about 100-200kHz or so where I can reasonably get that much current through the coil. But my main problem still remains. How would one make a constant current output into an inductor with the circuit?
To simplify things, I found a really nice power op-amp IC that looks like it should great for the frequency range I want to work in:
http://www.mouser.com/ProductDetail/Texas-Instruments/OPA541AP/?qs=sGAEpiMZZMtCHixnSjNA6Mrdwin7F8A2zuoa2IM%252bibI%3d
But the voltage to current converter circuit is still a challenge. Would work great using the circuit from the Wikipedia page it I weren't trying to drive an inductive load.
Thanks,
Jason O
Circuit from Wikipedia page should work with following modifications.
For power supplies use +12 volt with negative grounded and -12 volt with positive grounded. (Standard connection for power supplies)
Delete Dz and Rz
Apply sine wave signal to operational amplifier + input/ground
Expect to get maximum output voltage of about +/-10 volt or about 3.5 VRMS.
Hello Everyone,
I'm still putzing around with this amplifier design. I finally decided to not concern myself with the current control aspect for now as I am running into another problem, that being bandwidth. I did several simulations in Multisim to see how high a frequency I could push the design from pg. 22 of the link I referenced in my first post (http://www.wadsworthmedia.com/marketing/sample_chapters/1401848567_ch05.pdf). But as the PDF itself also states, this design tops out around 200-300 kHz as the crossover distortion gets ridiculous if you push it any faster.
I'm wondering if anyone here knows of an alternative design that could make it up to around 1MHz? I don't know enough about the subject and I'm not sure what I should be searching for. Most of what I find is either related to Audio amps or RF power radio amps, which all leave a big void in the range of 100kHz to 1MHz, which is what I would like to also operate in. Is there even a such thing as a DC-1MHz power amplifier??
Thanks,
Jason O
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
