Proving Vector Subspaces with Linear Transformations | Homework Help
boneill3
Let V and W be vector spaces over F and T:V \rightarrow W a linear transformation. Prove that ker(T):={\epsilon V\mid T()=0_{v}} is a vector subspace of V
Is it all right just to state the trivial solution.
ie There exists the vector 0v\epsilon V such that
T(0v) \rightarrow W_{0}
therfore the vector 0v\epsilon V is also 0v\epsilon T
or do I need more Axioms like
There exists the vectors -v\epsilon V and v\epsilon V such that
T(-v+v) = T(0v) \rightarrow W_{0}
to prove that T() is a vector subspace of V
regards
Brendan
You're trying to prove that ker(T) is a subspace, so you have to show that 0 is in ker(T). Moreover, you have to show that if u and v are in ker(T), then so is u + v. Finally, if u is in ker(T) and c is a scalar, then you have to show that c*u is in ker(T). These all follow directly from the basic properties of linear transformations.
Thanks for your help.
As a subspace always has the zero vector can I just say that for
{u,v} both elemants of V.
We have
0v = A
0u = B
Ax= 0 and Ay = 0, then A(x + y) = vx + vy = 0 + 0 = 0
Ax = 0 and c is a scalar, then A(cx) = cAx = c0 = 0
{Ax ,Bu} = 0 and c is a scalar, then Acx+Bcy = cAx+cBy = c0 + c0 = 0+0 = 0
Is that allright?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
