Linear Transformation and Null Space
Random Variable
Let (u,v,w) be a basis for vector space V, and let L be a linear transformation from V to vector space W. If (L(u),L(v),L(w)) is linearly dependent, then dim(Null Space(L)) > 1.
I don't see why dim(Null Space(L)) must be strictly greater than 1.
My proof that the dim(Null Space(L))>=1:
Let x be a vector in V that is in the Null Space of L.
Then L(x) = L(αu+βv+γw) = 0
L(αu)+L(βv)+L(γw) = 0
αL(u)+βL(v)+γL(w) = 0
Since the family (L(u),L(v),L(w)) is linearly dependent, α, β,, and γ are not all zero.
Therefore, Null Space(L) ≠ {0}, which implies that the dim(Null Space(L)) is at least 1.
You are right, it should be dim(Null Space(L)) >= 1. (Try constructing an example where dim(Null Space(L))=1.)
A small remark concerning your proof: when you say "α, β,, and γ are not all zero" you should instead write that "α, β,, and γ can be chosen so that not all are zero", because they can be all 0 (for x the zero vector). Then you can infer that x can be nonzero by reading the last three lines backwards.
Revised Proof:
Since the family (L(u),L(v),L(w)) is linearly dependent, α,β,and γ may not all be zero.
Therefore, Null Space(L) consists of more than just the zero vector, which implies dim(Null Space(L)) is not zero.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
