Little question for mechanical engineering
A user seeks to connect with a mechanical engineer through private messaging. Other forum members encourage posting the question publicly to receive diverse responses. They emphasize the value of open discussions in a forum setting rather than private communication. The consensus is that questions should be shared in the thread for broader engagement. Engaging openly in forums fosters community support and knowledge sharing.
qwerty321
hello..i just have a question to ask for a mechanical engineering..if there is one please tell me so i can PM him
thanks
If you insist upon communicating via PM, I'm sure that one will contact you before too long. Why not just post your question here, though?
He would be better off asking his question in the thread, I'm not interested in communicating through PM's. The purpose of a forum like this is getting many responses from many people.
I will not communicate through PM either. Don't come to a public forum if you don't want your conversation public as well.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
