Load Displacement to stress strain
3 replies · 12K views · last reply
8-)
Hello, so here is my problem.
I am given tensile data, which is displacement (mm) and load (kgf). also I am given width(mm), thickness(mm), gauge length (mm) and cross-head speed (mm/min). How do i make a stress strain curve from this?
So far i have multiplied width by thickness to find cross sectional area (in metres squared). Then i divide load (kgf) *9.8/cross sectional area (m^2) to find stress. and displacement (metres) over gauge length (metres) to find strain. I am getting around 65,000,000 pascals for maximum stress at around 40% strain. its for PVC. does that make sense?
thanks!
not compared with steel whose weakest strength would be around 250,000 pascals. (Check this yourself from some independent source)
If you search www.matweb.com for PVC, and read the material specs carefully, you may find data to compare with your results.
