Loading the magnetic field of an inductor
The discussion centers on calculating the optimal pulse width for a square wave applied to a high-inductance air-cored coil to maximize energy storage without excess current flow. Participants highlight that resistive losses are unavoidable and emphasize the importance of understanding the coil's direct current resistance (DCR) and the inductance-resistance (LR) time constant. Suggestions include charging the coil for several time constants per pulse to effectively load the magnetic field. Clarification on the definition of "completely loading" the coil is sought, as the current is ultimately limited by the source voltage and coil resistance. The conversation underscores the need for precise measurements and calculations to optimize energy efficiency in the experiment.
Jdo300
Hello all,
I have a simple experiment I'm working on where I am pulsing square waves into an air-cored coil with a high inductance (in the mH range). I am wondering if there is a way to calculate what pulse width, on the square wave, I would need to use to completely load the magnetic field of the coil, but no more. I want to see how much of the stored energy I can get back from the field (minus the resistive losses). Ideally, I want all the input power to go into the field and then the pulse would shut off before extra power is wasted and unnecessary current flows through the coil. Any pointers are welcome.
Thanks,
Jason O
you can't avoid resistive losses, it's not like an overflowing cup type thing where if you "fill up" the field and then stop none will be lost to resistance.
Jdo300 said:
Hello all,
Thanks,
Jason O
I'm not sure what you mean by completely loading the coil. The current is limited by the source voltage and the DCR of the coil. You can calculate the LR time constant, and charge the coil for a few time constants per pulse. What's your DCR? (If it's low, be sure to subtract out your DVM lead resistances in the final reading.)
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
