Locate and Classify Singularities
  • Thread starter Thread starter jjangub
    Singularities
jjangub
Locate and classify the singularities of the following functions
a) f(z) = 1 / (z^3*(z^2+1))
b) f(z) = (1 - e^z)/z
c) f(z) = 1 / (1-e^z(^2))
d) f(z) = z / (e^(1/z))
I am not sure what I need to do when it asks me to locate and classify the singularities. I tried this way.
a) f(z) has singularities when z = i or -i and singularities are fifth order poles.
(z^3*(z^2+1) = z^5 + z^3
b) f(z) has essential singularity at 0 because f(z) is defined in the whole complex plane except for z = 0.
c) f(z) has essential singularity at 0 because f(z) is defined in the whole complex plane except for z = 0.
d) since we know e^(1/z) is essential singularity at 0, f(z) = z / (e^(1/z)) is same.
Did I do right?
Please tell me if I did something wrong.
Thank you.
Need to write those in quotient form. It's easier to talk about the singularities that way.
(a)\quad \frac{1}{z^3(z^2+1)}
Ok, that one has a third-order pole at zero and simple poles at \pm i right?
(b)\quad \frac{1-e^z}{z}
That has a limit as z\to 0 so has a removable singularity at zero.
(c)\quad \frac{1}{1-e^{z^2}}
That one is tricky because e^u is entire so reaches every value, except maybe one, infinitely often so can you solve multiwise:
e^{z^2}=1
I mean:
z^2=\log(1)
z=\sqrt{\ln|1|+i(0+2n\pi)}
z=\sqrt{2n\pi i},\quad n=0,\pm 1,\pm2,\cdots
So (c) has a pole at those values of z. Keep in mind the square root is double-valued also, so the poles are along the two rays with arguments \pi/4 and -3\pi /4. What are the orders of those poles? Can you figure out what the order of the one at zero is if I write it as:
-\frac{1}{\sum_{n=1}^{\infty} \frac{z^{2n}}{n!}}
And (d) is the canonical form of an essential singularity (e^{1/z}). You can write the taylor series for e^{w} and then substitute w=1/z, z\ne 0[/tex] and obtain a Laurent series with a non-terminating singular part (the part with powers of z in the denominator). Also, e^u is entire and non-polynomial so then has an essential singularity at infinity (Picard) which means e^{1/z}[/tex] has one at zero.
I understand most of them excpet c).
Could you explain again about c)?
Thank you.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
