Location of minimum change in velocity for orbit escape
To achieve escape velocity from an elliptic orbit, the rocket's engine should be fired at either the apogee or perigee, but the optimal choice depends on the interplay between kinetic and potential energy. The escape velocity equation indicates that the farther the rocket is from the Earth, the lower the required escape velocity, suggesting that firing at apogee may be advantageous. However, at perigee, the rocket has a higher speed, which could compensate for the increased escape velocity needed. Calculating the orbital speed and escape velocity at both points will clarify the required delta-v for each scenario. The direction of the thrust should be aligned to maximize the resultant velocity vector, enhancing the chances of successful escape.
majorbromly
A rocket is in elliptic orbit about the earth. To put it into escape
velocity, its engine is fired briefly, changing the rocket’s velocity by
deltaV . Where in the orbit, and in what direction, should the firing occur
to attain escape with a minimum value of deltav
E=-c/A
Vescape=sqrt(2GM/r)
I honestly have not been able to get anything meaningful.
I attempted to set kinetic and potential energies equal, as that's when the orbit becomes parabolic and escapes, but I have not really been able to glean any information about where the rockets should be fired.
It's quite obvious to me that it should be one of the two end points. But the relative interplay between K and U is something I can't quite prove.
Any help would be appreciated.
Your equation for escape velocity says that the farther away you are, the smaller your escape velocity is. I imagine that the best point would be at apogee (the farther point of the orbit).
That makes sense. However, at the closest point in the orbit, the object will be going much faster as well...which may or may not compensate for the increase in escape velocity. My problem is essentially that.
I have a decent proof for the direction of the thrust (although this is obvious in the first place of course). But I just cannot mathematically prove if it should be the apogee or perigee. It seems that either is equally as valid.
However, I've seen elsewhere that the rocket should be fired at it's closest pass to the planet.
Calculate the orbit speed at each of your candidate points. Also calculate the escape velocity at that radius. What are the required Δv's at each point?
As for the direction, for a Δv that occurs over a small time interval (i.e. essentially an impulse), how would you combine the initial velocity and the Δv to find the final velocity vector? What Δv direction maximizes the sum?
Ahh, I think I have it. Thanks!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
