Minimum kgf/N for a 4m x 2.5m Door - Outdoor Wind Resistance
The minimum holding force required for a 4m x 2.5m outdoor door is approximately 490 N, equivalent to supporting a weight of around 49 kg. The effectiveness of the magnet depends on its strength, the materials of the door, and whether it is fixed or tied down. High winds can exert significantly more force, so it's important to consider the wind speed when selecting a magnet. A magnet with a holding power of 490 N should suffice for a lighter door, but stronger options may be necessary for higher wind resistance. Proper calculations and considerations for wind conditions are crucial for ensuring the door remains secure.
josh.k.abbott
Hi
What is the minimum kgf (or N) of a magnet to hold a 4m x 2.5m door?
The door will be outdoor and wind can hit it. The function of the magnet is to keep it open.
Best regards
josh
depends on the strength of the magnet and how you plan to keep the magnet in place. if you want the magnet to keep itself in place, then it needs to weigh just as much as the door. if you tie it to something then it may be able to hold.
it also depends on the conductivity of the door's materials. a 2 tesla magnet, is pretty expensive, but can create forces of roughly the same magnitude as one can pull or push with a hand.
fortunately for you that website is telling you what the holding power is. It says that given that you use a VDS coil on the door, so that the magnet is in touch with the coil, the holding power is 490N, which translates to an object as heavy as roughly 49kg. So if the door is only say 20kg, then there's some degree of strength even with the winds. Although high winds can achieve much higher forces, on occasion.
On a practical note, maybe you want the magnet overcome at a lower wind speed than a higher one. A 10 km/hr breeze slamming a door shut won't be quite as annoying as a 90 km/hr wind gust doing it.
KABOOM!
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
