Is My Logarithmic Differentiation Method Correct?
In summary, the person is trying to find the y-value of x^3 - x^2, but gets lost. They try using logarithmic differentiation but get confused. They end up using the method suggested by another user and get the correct result.
t_n_p
595
http://img253.imageshack.us/img253/5748/logdiffji4.jpg
I've tried both and i) and ii) however something just doesn't seem right. Can somebody tell me if my method is correct?
i) http://img253.imageshack.us/img253/8791/img0186anh3.jpg ii)http://img329.imageshack.us/img329/627/img0187azr5.jpg
You forgot to differentiate.
I've got a total mindblock :yuck: , can you explain a little further?
differentiate both right and left hand side...
Oh yeh! I tried by using chain rule (Let sinx^cosx = u)
therefore i get :
(1/y)*(dy/dx) = (1/u)*[d/dx(sinx^cosx)]
How would I go about diff-ing sinx^cosx?
consider cosx as u and log(sinx) as v, then diff by the product rule (udv+vdu)
In diff. v, use the chain rule
Ah! so much easier!
Ok, after that tip from f(x) I got what I believe is the final answer. Can this be simplified any further?
http://img156.imageshack.us/img156/115/img0192us4.jpg
Your work looks good up until very last step. Try that final step one more time.
silly me! :rofl:
2nd time lucky!
http://img441.imageshack.us/img441/8141/answerem9.jpg
Much better.
I'm not too sure how to go about part (ii)
So far I've converted the square roots to ^1/2 and expanded out to get
x^(3/2)[(1-x^2)^(1/4)]
I then let that equal u (chain rule) however the product rule within u seems to get pretty messy/complicated.
Is this the correct method?
If [itex]y=x^{3/2}[(1-x^2)^{1/4}],[/itex] then let [itex]u=x^{3/2} [/itex]and [itex]v=(1-x^2)^{1/4} [/itex] so that y'=uv'+u'v, remembering that to calculate v' you will need to use the chain rule.
Ok, so I now know how to diff [itex]y=x^{3/2}[(1-x^2)^{1/4}],[/itex] but shouldn't I take log of both sides before diff-ing? In that case I need to figure out the derivative of ln[[itex]y=x^{3/2}[(1-x^2)^{1/4}],[/itex]]
Bump, can anybody help?
You could but you don't have to. Typically "logarithmic differentiation is used when you have a function of x in the exponent.
Just use the product rule:
[itex]y'= (x^{3/2})'(1- x^2)^{1/4}+ x^{3/2}[(1-x^2)^{1/4}]'[/itex]
[itex]= (3/2)x^{1/2}(1- x^2)^{1/4}+ (x^{3/2})(1/4)(1-x^2)^{-3/4}[/itex]
If you take the logarithm of both sides, you get [itex]ln y= (3/2)ln(x)+ (1/4)ln(1+ x^2)[/itex]. Now [itex](1/y)y'= 3/(2x)+ 2x/(4(1+x^2))[/itex]. That righthand side is much simpler but you still have to multiply by y.
Another way to differentiate the second expression is to change it to a single n-root, like this:
[tex]\sqrt{x ^ 3 \sqrt{1 - x ^ 2}} = \sqrt{\sqrt{x ^ 6 (1 - x ^ 2)}} = \sqrt[4]{x ^ 6 - x ^ 8}[/tex]
Let u = x6 - x 8. Now, the whole expression becomes [tex]\sqrt[4]{u}[/tex], you can apply the chain rule and finish the problem. Can you go from here? :)
I think ill go with this method. So using chain rule I get dy/dx = (1/4)((x^6-x^8)^(-3/4))*(6x^5-8x^7)
Hope you can make that out. So where does the logarithmic part come into it? Do I now take log of both sides?
I'm quite lost:confused:
Nope, you can differentiate it normally as you've just done.
Or you can tuse logarithmic differentiation as HOI has suggested, i.e, it goes like this:
[tex]y = \sqrt{x ^ 3 \sqrt{1 - x ^ 2}}[/tex]
Taking log of both sides yields:
[tex]\ln y = \ln \left( \sqrt{x ^ 3 \sqrt{1 - x ^ 2}} \right) = \frac{1}{2} \ln \left( x ^ 3 \sqrt{1 - x ^ 2} \right) = \frac{1}{2} \left( \ln (x ^ 3) + \ln( \sqrt{1 - x ^ 2} ) \right)[/tex]
Now, you can differentiate both sides to find y'.
There are many ways to approach a differentiation problem, so just choose the one that you like best.
That's very helpful! Had to navigate through the diff of [tex]\frac{1}{2} \left( \ln (x ^ 3) + \ln( \sqrt{1 - x ^ 2} ) \right)[/tex]. Was a bit tricky but I think I got it...
http://img253.imageshack.us/img253/6788/asdfry0.jpg
Can you please confirm?
Nope, still incorrect. You forget to multiply it by y.
Multiply it by y, then simplify the expression you get, and it's all done. :)
Note that differentiating [tex]\ln( \sqrt{1 - x ^ 2} )[/tex] can be a little bit tricky, but if you pull out the 1/2, it should be easier. It goes like this:
[tex][\ln( \sqrt{1 - x ^ 2} ) ]' = \frac{1}{2} [\ln (1 - x ^ 2) ]' = \frac{1}{2} \times \frac{-2x}{1 - x ^ 2} = \frac{-x}{1 - x ^ 2}[/tex] :)
Yeh, that was just the diff without * y.
After making common denom of (6x^3)(4-4x^2) and * by y I get
http://img242.imageshack.us/img242/5305/finalansux3.jpg
[/URL]
You still haven't simplified it... =.="
HINT: You can factor out x2 in the numerator and denominator, then the two x2's will cancel each other out.
[tex]y \times \left( \frac{3x ^ 2}{6x ^ 3} - \frac{2x}{4 - 4 x ^ 2} \right) = \sqrt{x ^ 3 \sqrt{1 - x ^ 2}} \times \left( \frac{1}{2x} - \frac{x}{2 - 2 x ^ 2} \right)[/tex]
[tex]= \frac{1}{2}\sqrt{x ^ 3 \sqrt{1 - x ^ 2}} \times \left( \frac{1}{x} - \frac{x}{1 - x ^ 2} \right)[/tex]
And... you can stop here, and leave it in this form. :smile: It's okay, simplified enough. You shouldn't make common denominator, as it's unnecessary, and you may also make some minor mistakes during doing so.
Finally got it. Many, many thanks!
1. What is logarithmic differentiation?
Logarithmic differentiation is a method used to differentiate functions that involve logarithms. It involves taking the natural logarithm of both sides of an equation and then using the properties of logarithms to simplify the expression before differentiating.
2. When is logarithmic differentiation used?
Logarithmic differentiation is used when a function involves both exponential and logarithmic terms, making it difficult to differentiate using traditional methods. It is also useful for finding derivatives of functions that involve products, quotients, or powers.
3. How is logarithmic differentiation performed?
To perform logarithmic differentiation, first take the natural logarithm of both sides of the equation. Then, use the properties of logarithms to simplify the expression. Next, take the derivative of both sides with respect to the variable of interest. Finally, solve for the desired derivative.
4. What are the advantages of using logarithmic differentiation?
One advantage of logarithmic differentiation is that it allows us to differentiate functions that would otherwise be difficult or impossible to differentiate using traditional methods. It also simplifies the process of finding derivatives of functions that involve both exponential and logarithmic terms.
5. Are there any limitations to using logarithmic differentiation?
Logarithmic differentiation can be time-consuming and may require a good understanding of logarithmic properties. It also may not always be the most efficient method of finding derivatives. Additionally, it may not be applicable to functions that do not involve logarithms or exponential terms.
11K
