Is This Example Correctly Solved Using Logarithmic Differentiation?
surferbarney0729
Something about this worked problem looks off. Is this example correctly solved using logarithmic differentiation?
The original problem is y = (2-x)^(sqrt x). If anyone who is rather confident with this could double check this example it would really help me out. Thanks. I attached the link to reduce my typing confusion.
http://archives.math.utk.edu/visual.calculus/3/logdiff.1/a1.gif
Here's the image:
What is it that looks off to you?
I can not pinpoint anything. I am aware of the steps of the log diff for other examples on this weeks homework. Prof through it out to the class that this looks off. I can't see it. Should I look deeper?
Looks perfectly fine to me.
Provided you understand the product rule, the chain rule, and the fact that ln(a^b) = b.ln(a), there isn't really anything mysterious here at all.
ok thanks. Perhaps it was thrown out to check our grasp of your aforementioned rules. Thanks for the time.
I threw this out last night, but it is still getting some pushback.
How does this look? Right or a little off? I placed the problem and solution link since I can not figure out how to import the image.
http://archives.math.utk.edu/visual...gdiff.1/a1.gif
This is what I get when trying to look at the image:
The requested URL /visual...gdiff.1/a1.gif was not found on this server.
Does this work,
The original problem is...
y = (2-x)^sqrt(x)
And you want the derivative?
yes, using logarithmic differentiation solve the problem.
In general, when you have something like f(x)^{g(x)} you can find the derivative like this, which should give you what you need to solve your specific problem where log is the natural logarithm:
y=f(x)^{g(x)}
\log{y}=g(x)\log{f(x)}
Implicitly differentiate both sides:
\frac{dy}{y}=g'(x)\log{f(x)}dx+\frac{g(x)f'(x)}{f(x)}dx
y'=y\left(g'(x)\log{f(x)}+\frac{g(x)f'(x)}{f(x)} \right)
y'=f(x)^{g(x)}\left(g'(x)\log{f(x)}+\frac{g(x)f'(x)}{f(x)}\right)
It looks fine.
DonAntonio
Your efforts to spread this question to a larger audience have obviously been quashed, as it looks like it's been merged into your original thread!
What exactly do you mean by "some pushback"? Has your Prof said something? If so, what? Is he/she worried about the domain/range not being real etc?
Even the God Almighty that is Woolfy-Alfa agrees that this is the correct solution.
