Logarithmic Help: Solving for z, m & n
  • Thread starter Thread starter stosw
    Logarithmic
The discussion focuses on solving for variables z, m, and n using logarithmic properties in a homework problem. The initial attempts successfully calculated some values using the logarithm of 2 and 1.1, but similar methods failed for the remaining variables. Participants suggest approximating numbers like 2 and 3 as powers of 1.1, specifically 1.1^N and 1.1^M. The exercise emphasizes understanding the relationship between exponential and logarithmic forms to derive the correct values. Overall, the key is to apply logarithmic properties consistently to find the desired solutions.
stosw
http://img20.imageshack.us/img20/1476/mathproblemi.jpg
Properties of logs.
For the first two I did:
Int( \frac{Log(2)}{Log(1.1)} )
Doing this resulted in the correct answers for the first two boxes. When I try similar techniques to solve for z, m,n I get incorrect answers.
Anyone have tips or suggestions on how to go about finding these?
Your task is to approximate 2 and 3 as 1.1^N and 1.1^M, and solve z from there.
If 1.1^7 is approximately 2 then 2^x is approximately (1.1^7)^x= 1.1^{7x}. That's the point of this exercise.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
