Logic Circuit Design: Controlling an Electromagnet with a Micro Switch
The discussion focuses on using a micro switch to control an electromagnet on a steel wall, where the electromagnet is activated just before contact and deactivated just before losing contact. A truth table and logic circuit design are requested for this setup, but there is confusion about the requirements. One participant clarifies that a complex logic circuit is unnecessary, as the operation involves simply using the switch to control the magnet's on and off states during movement. The process involves the magnet energizing, making contact, the switch opening, and then de-energizing as it swings away. The main takeaway is the simplicity of the control mechanism rather than a detailed logic design.
vivazza
i need help for my assignment.
On a steel wall, the micro switch is used to activate and deactivate the electromagnet. Electromagnet will be energized just before it touches the steel wall and de-energized jus before losing contact with the wall in both directions. Write truth table and design the logic circuit to control the electromagnet.
pls see the attachment for the picture. thanks alot
I'm afraid that I cannot even understand what this question is asking.
- Warren
a logic cct is not required.
you are simply using a switch to make and break a magnet (on one wall?).
*** magnet energizes- moves to wall- switch opens- magnet de energizes and swings away from wall- switch closes- magnet energizes-...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
