Logic Gates: Basics & Uses for O-Level Students
  • Thread starter Thread starter Chaulesh
    Logic Logic gates
Logic gates are fundamental components in digital circuits, functioning based on binary inputs to produce specific outputs. For O-Level students, understanding their basic principles and applications is crucial, particularly in simplifying logic expressions and constructing logical expressions from truth tables. It's recommended to review textbooks and supplementary materials tailored for O-Level revision to grasp these concepts effectively. Practicing problems related to logic gates will enhance understanding and preparation for exams. Utilizing resources like Wikipedia can also provide a solid foundational overview.
Chaulesh
Hi! I'm new to this forum, just joined a couple of hours ago. I am an O-Level student and I am currently on revision leave. I would like some explanations on the basic working principle of logic gates and their uses in special circuits. The clearer the explanation the better and some links to good sites would be of no refusal. Thank you in advance!
Hi,
The problem with such a question is that it's not evident to most posters here since they've probably done their 'O' Levels a long time ago (just as I did) and may not know exactly what you need to understand for the 'O' Levels. They may end up giving you a far more detailed and advanced explanation you will ever need and would end up confusing you.
What I did for my 'O' and 'A' levels revision was to reread the textbook and supplementary revision texts for a better explanation and understanding. It also helps to practice a lot. You'll be tested (if I can remember my O level stuff) on things like how to simplify logic expressions (by making use of the logic tables) and construct logical expressions just from a given logic table. There's probably more stuff you'll be examined on which I don't remember. Just look for a suitable O levels text.
Good luck!
maybe this should be moved to the EE forum.
in the meantime maybe start with Wikipedia:
http://en.wikipedia.org/wiki/Logic_gate
(also, the obligatory "welcome to PF, Chaulesh.")
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
